[geos-devel] [GEOS] #934: disable svn access from the web
GEOS geos-trac at osgeo.org
Mon Oct 8 15:10:14 PDT 2018
 Reporter:  gdt        |       Owner:  geos-devel@…
     Type:  task       |      Status:  closed
 Priority:  minor      |   Milestone:  Management
Component:  Default    |     Version:  master
 Severity:  Annoyance  |  Resolution:  fixed
 Keywords:             |
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 SVN was made read-only but still accessible as per #934 on April 5th 2017.
 Now I turned it completely inaccessible (forbidden) with custom error
 response pointing to https://trac.osgeo.org/geos/wiki/CodeRepository
 Unfortunately it doesn't look like {{{ git-svn }}} shows the custom
 response, didn't test direct SVN client
Ticket URL: <https://trac.osgeo.org/geos/ticket/934#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
