[geos-devel] test failure on master, libtool artifact
Greg Troxel
gdt at lexort.com
Mon Oct 8 17:06:42 PDT 2018
I have successfully run the tests building from the git 3.7 branch on
NetBSD 7 amd64, with pkgsrc libtool.
On master, I got a segfault in geos_unit. On investigating, I find that
the test binary is somehow linking in geos-3.7.0. If I install the
master build (3.8), and run geos_unit manually (without the autotools
wrapper), then it passes.
This could of course be a NetBSD/libtool issue. But I wonder if anyone
else is seeing issues, specifically on a system with geos release 3.7
installed, when running make check under an autotools build of git
master.
The cmake build does not appear to build geos_unit in the same place,
but I don't understand how 'make check' under cmake is supposed to work.
I do get a failure in that case too (on master; on 3.7 the cmake build
does not complete):
Test project /home/gdt/SOFTWARE/POSTGIS/geos-master/build
Start 1: test_geos_unit
1/8 Test #1: test_geos_unit ...................***Failed 0.62 sec
Start 2: test_xmltester
2/8 Test #2: test_xmltester ................... Passed 18.28 sec
[rest is ok]
