[geos-devel] RFC7 - Use CMake as build system for GEOS
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 19 10:38:41 PDT 2018
Or maybe I should attempt to summarize what I recall from the thread that
seem to me to be reasonable functional requests before going cmake-only:
- make dist generates a distributable tarball
- make check
- make check runs all tests
- make check builds test binaries that can be debugged w/o an install
More?
P
On Fri, Oct 19, 2018 at 10:36 AM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> This conversation seems to have veered off.
> Dan asked what I think is a reasonable question:
> Is having working 'make dist' and 'make distclean' targets sufficient to
> move to a cmake-only build, or will the goalposts just shift again to some
> other metric (like build time, referenced above)?
> I have a branch that seems to have an OK 'make dist' target that I'll PR
> shortly. I'm not sure that 'make distclean' is actually applicable to the
> cmake build process, since 'distclean' as a target is something that
> autotools needs to deal with the fact that autotools creates so many build
> artifacts that aren't wanted in the source bundle. In a cmake build run
> from a separate build tree (not run "in tree" like autotools) the 'dist'
> target seems sufficient to our purpose (get a deterministic source tarball)
> without a 'distclean' but we'll see.
> I am among those who would (a) like to have one build system and (b) would
> like cmake to be that build system.
> P
> On Thu, Oct 4, 2018 at 7:41 AM Sandro Santilli <strk at kbt.io> wrote:
>> On Thu, Oct 04, 2018 at 04:16:28PM +0200, Sandro Santilli wrote:
>> > Install/uninstall steps:
>> > build-cmake$ time sudo make install
>> > real 0m1.514s
>> > user 0m0.403s
>> > sys 0m0.232s
>> > build-autotools$ time sudo make install
>> > real 0m10.302s
>> > user 0m9.643s
>> > sys 0m0.737s
>> > Note that the extra time on "make install" for autotools
>> > is due to some problematic dependency encoded to deal with
>> > GEOS revision flag, used to build final library (not sure
>> > a ticket exists for that already)
>> After fixing the bug in tools/repo_revision.sh these are
>> the new timings (cmake twice as fast at install):
>> real 0m2.905s
>> user 0m2.379s
>> sys 0m0.595s
>> --strk;
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20181019/2530c7b2/attachment.html>
