[geos-devel] [GEOS] #937: geos/.h files not available in framework Headers
geos-trac at osgeo.org
Sat Oct 20 04:18:48 PDT 2018
Reporter: xzcvczx | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Build/Install (cmake) | Version: 3.6.2
Severity: Unassigned | Keywords:
If you build geos as a framework then and -Ipath/to/GEOS.framework/Headers
you can't use <geos/export.h> for example as there is no geos folder in
headers.
as all the files are in the root of headers this can easily be worked
around by creating a symlink named geos to the Headers directory,
Ticket URL: <https://trac.osgeo.org/geos/ticket/937>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
