[geos-devel] [GEOS] #937: geos/.h files not available in framework Headers
GEOS geos-trac at osgeo.org
Sat Oct 20 08:02:21 PDT 2018
 Reporter:  xzcvczx                |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  minor                  |   Milestone:
Component:  Build/Install (cmake)  |     Version:  3.6.2
 Severity:  Unassigned             |  Resolution:  invalid
 Keywords:                         |
Changes (by kyngchaos):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Actually, the way framework headers work, including <geos/whatever.h>
 works without using any -I flags.  The build system tries frameworks that
 match the first part of the path in the <>.  So, it knows that
 <geos/whatever.h> is the GEOS framework (names are not case sensitive) and
 look for the "whatever.h" file in the framework's Headers folder.  Using a
 -I flag should not interfere with this.
 And, there already is a symlink if really needed for some reason.  It's in
 the "unix" folder, along with other standard unix-style folders, bin,
 include and lib.  This simulates a unix style build, with the geos-config
 bin, and c and c++ library names.
Ticket URL: <https://trac.osgeo.org/geos/ticket/937#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
