[geos-devel] [GEOS] #938: CMake builds on winnie failing
GEOS geos-trac at osgeo.org
Sat Oct 20 20:16:10 PDT 2018
 Reporter:  robe        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  blocker     |  Milestone:  3.8.0
Component:  Default     |    Version:  master
 Severity:  Unassigned  |   Keywords:
 Builds of master seem to be failing as of Oct 19th.
 Latest getting this error:
 Assembler messages:
 Fatal error: can't create CMakeFiles/geos-
 static.dir/operation/overlay/PolygonBuilder.cpp.obj: No such file or
 directory
 src/CMakeFiles/geos-static.dir/build.make:5438: recipe for target
 'src/CMakeFiles/geos-static.dir/operation/overlay/PolygonBuilder.cpp.obj'
 failed
 make[2]: *** [src/CMakeFiles/geos-
 static.dir/operation/overlay/PolygonBuilder.cpp.obj] Error 1
 CMakeFiles/Makefile2:238: recipe for target 'src/CMakeFiles/geos-
 static.dir/all' failed
 make[1]: *** [src/CMakeFiles/geos-static.dir/all] Error 2
 Makefile:138: recipe for target 'all' failed
 make: *** [all] Error 2
 make: *** No rule to make target 'check'.  Stop.
 make: *** No targets specified and no makefile found.  Stop.
 Last successful was: Commit e2b85688c9e043a096a0161f59cb6fa9c142f868
 (John.Harvey)
     'make check' passes with autoconf 2.63. (details)
Ticket URL: <https://trac.osgeo.org/geos/ticket/938>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
