[geos-devel] RFC7 - Use CMake as build system for GEOS
Sandro Santilli
strk at kbt.io
Sun Oct 21 02:43:39 PDT 2018
On Fri, Oct 19, 2018 at 10:38:41AM -0700, Paul Ramsey wrote:
> Or maybe I should attempt to summarize what I recall from the thread that
> seem to me to be reasonable functional requests before going cmake-only:
> - make dist generates a distributable tarball
> - make check
> - make check runs all tests
> - make check builds test binaries that can be debugged w/o an install
The "distclean" rule you were asking about is for in-source builds.
Both automake _and_ cmake support both in-source and off-source builds.
In addition to the above autotools also has a "distcheck" rule, which
runs "make dist" and then:
(1) unpacks the resulting tarball in a new sourcedir
(2) makes the new sourcedir read-only
(3) configures and builds in a new build dir
(4) runs "make check"
(5) installs in a new empty directory, uninstalls
and checks that the install dir is again empty
So basically "distcheck" ensures that the distributed tarball works.
--strk;
