[geos-devel] [GEOS] #941: Incorrect values returned on error in CAPI
geos-trac at osgeo.org
Sat Oct 27 12:23:58 PDT 2018
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.6.2
Severity: Unassigned | Keywords:
In some cases, the CAPI function `GEOSLength_r` returns `2` on error, when
it is documented to return `0`. The `2` is likely to be interpreted as
"success" by a caller.
In some cases, the CAPI function `GEOSIsValidDetail_r` returns `0` on
error, when it is documented to return `2`. The `0` would be falsely
interpreted as "geometry invalid."
Ticket URL: <https://trac.osgeo.org/geos/ticket/941>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
