[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
geos-trac at osgeo.org
Sun Sep 2 11:39:17 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by Regina Obe <lr@…>):
In [changeset:"5ccb3fa3062347c36e4129e3bd45b9486a30f66d/git" 5ccb3fa/git]:
#!CommitTicketReference repository="git"
revision="5ccb3fa3062347c36e4129e3bd45b9486a30f66d"
Take out failing test on FreeBSD/macOS Clang. References #894
Will revisit in 3.8
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
