[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
geos-trac at osgeo.org
Mon Sep 3 11:09:35 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by robe):
Forgot to reference the ticket number
In [changeset:"2644482da4779ad726a500a8a5bd7d2453cebdb2/git" 2644482/git]:
#!CommitTicketReference repository="git"
revision="2644482da4779ad726a500a8a5bd7d2453cebdb2"
Change to ignore failure in CoordinateArraySequenceFactoryTest. Put back
UniqueCoordinateArrayFilterTest.
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:14>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
