[geos-devel] [GEOS] #923: Memory leak in GEOSNode
GEOS geos-trac at osgeo.org
Tue Sep 18 15:30:12 PDT 2018
 Reporter:  Algunenano   |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.7.0
Component:  Default      |     Version:  master
 Severity:  Significant  |  Resolution:
 Keywords:               |
Comment (by cvvergara):
 Doing the same but with
 git checkout -b three-weeks-ago 1be02b3644672ac97842bfa2ad4cb2810696dc75
 with clang
 $clang -fsanitize=address geos_leak.c -lgeos_c
 -L/home/vicky/geos/vicky/build/lib -I/home/vicky/geos/vicky/build/include
 -I /home/vicky/geos/vicky/include
 $ ./a.out
 using vlagrind
 $ gcc  geos_leak.c -lgeos_c -L/home/vicky/geos/vicky/build/lib
 -I/home/vicky/geos/vicky/build/include -I /home/vicky/geos/vicky/include
 $ valgrind --leak-check=yes  ./a.out
 ==6163== Memcheck, a memory error detector
 ==6163== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
 ==6163== Using Valgrind-3.11.0 and LibVEX; rerun with -h for copyright
 info
 ==6163== Command: ./a.out
 ==6163==
 ==6163==
 ==6163== HEAP SUMMARY:
 ==6163==     in use at exit: 73,848 bytes in 4 blocks
 ==6163==   total heap usage: 65 allocs, 61 frees, 81,840 bytes allocated
 ==6163==
 ==6163== LEAK SUMMARY:
 ==6163==    definitely lost: 0 bytes in 0 blocks
 ==6163==    indirectly lost: 0 bytes in 0 blocks
 ==6163==      possibly lost: 0 bytes in 0 blocks
 ==6163==    still reachable: 73,848 bytes in 4 blocks
 ==6163==         suppressed: 0 bytes in 0 blocks
 ==6163== Reachable blocks (those to which a pointer was found) are not
 shown.
 ==6163== To see them, rerun with: --leak-check=full --show-leak-kinds=all
 ==6163==
 ==6163== For counts of detected and suppressed errors, rerun with: -v
 ==6163== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
 The output looks the same to me for both commits on the commit history.
 Maybe I am doing something wrong, I cant reproduce the problem.
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
