[geos-devel] [GEOS] #923: Memory leak in GEOSNode
GEOS geos-trac at osgeo.org
Wed Sep 19 02:04:02 PDT 2018
 Reporter:  Algunenano   |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.7.0
Component:  Default      |     Version:  master
 Severity:  Significant  |  Resolution:
 Keywords:               |
Comment (by Algunenano):
 > So I am trying to checkout that number as git commit
 It comes from calling `git describe --long --tags` in what was at that
 moment the current master/HEAD:
 $ git checkout be8b3ffb4532c5302e004a400bf0069493df7302
 Previous HEAD position was 642744e5 Fix typos in getGeometryN() docs.
 HEAD is now at be8b3ffb Merge branch 'fix-shadow4.8' of cvvergara/geos
 into master
 $ git describe --long --tags
 3.7.0rc1-21-gbe8b3ffb
 To be honest, I'm not sure how `gbe8b3ffb` relates to the commit.
 Here is a step by step guide to reproduce the issue:
 - Checkout commit before the one responsible (`^` means commit before this
 one):
 git checkout e7adbc55a20633064d3af49f2662b17e5ca02e47^
 - Build the library (set up flags as needed):
 ./autogen.sh
 ./configure
 make
 - Build the test file (I placed it in the same folder as the library
 (`~/dev/public/geos`):
 clang -fsanitize=address geos_leak.c -lgeos_c -L./capi/.libs -L./src/.libs
 -Iinclude/geos
 - Run forcing the use of the local built library:
 LD_LIBRARY_PATH=./capi/.libs:./src/.libs ./a.out
 (no output)
 - Switch to the offending commit:
 - Rebuild the library:
 make
 - Run the test binary using the newly compiled library (There is no need
 to recompile it since it was linked dynamically):
 ==14385==ERROR: LeakSanitizer: detected memory leaks
 Indirect leak of 88 byte(s) in 1 object(s) allocated from:
     #0 0x55d4cca326a1 in __interceptor_malloc
 (/home/raul/dev/public/geos/a.out+0xe66a1)
     #1 0x7f9d7c33a5fc in operator new(unsigned long)
 /build/gcc/src/gcc/libstdc++-v3/libsupc++/new_op.cc:50:40
     #2 0x7f9d7c5463a2 in
 geos::noding::GeometryNoder::extractSegmentStrings(geos::geom::Geometry
 const&, std::vector<geos::noding::SegmentString*,
 std::allocator<geos::noding::SegmentString*> >&)
 /home/raul/dev/public/geos/src/noding/GeometryNoder.cpp:157:12
     #3 0x7f9d7c54684b in geos::noding::GeometryNoder::getNoded()
 /home/raul
 You can also avoid `clang` and instead build the test file normally and
 use valgrind:
 gcc geos_leak.c -lgeos_c -L./capi/.libs -L./src/.libs -Iinclude/geos
 Valgrind with the last good commit:
 $ LD_LIBRARY_PATH=./capi/.libs:./src/.libs valgrind ./a.out
 ==24076== Memcheck, a memory error detector
 ==24076== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
 ==24076== Using Valgrind-3.14.0.GIT and LibVEX; rerun with -h for
 copyright info
 ==24076== Command: ./a.out
 ==24076==
 ==24076==
 ==24076== HEAP SUMMARY:
 ==24076==     in use at exit: 1,152 bytes in 3 blocks
 ==24076==   total heap usage: 65 allocs, 62 frees, 81,848 bytes allocated
 ==24076==
 ==24076== LEAK SUMMARY:
 ==24076==    definitely lost: 0 bytes in 0 blocks
 ==24076==    indirectly lost: 0 bytes in 0 blocks
 ==24076==      possibly lost: 0 bytes in 0 blocks
 ==24076==    still reachable: 1,152 bytes in 3 blocks
 ==24076==         suppressed: 0 bytes in 0 blocks
 ==24076== Rerun with --leak-check=full to see details of leaked memory
 ==24076==
 ==24076== For counts of detected and suppressed errors, rerun with: -v
 ==24076== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
 Valgrind with the last valid commit:
 $ LD_LIBRARY_PATH=./capi/.libs:./src/.libs valgrind --leak-check=full
 ./a.out
 ==8512== Memcheck, a memory error detector
 ==8512== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
 ==8512== Using Valgrind-3.14.0.GIT and LibVEX; rerun with -h for copyright
 info
 ==8512== Command: ./a.out
 ==8512==
 ==8512==
 ==8512== HEAP SUMMARY:
 ==8512==     in use at exit: 1,512 bytes in 11 blocks
 ==8512==   total heap usage: 65 allocs, 54 frees, 81,848 bytes allocated
 ==8512==
 ==8512== 360 (88 direct, 272 indirect) bytes in 1 blocks are definitely
 lost in loss record 10 of 11
 ==8512==    at 0x4837DEF: operator new(unsigned long)
 (vg_replace_malloc.c:334)
 ==8512==    by 0x4B854E3: geos::noding::(anonymous
 namespace)::SegmentStringExtractor::filter_ro(geos::geom::Geometry const*)
 (GeometryNoder.cpp:61)
 ==8512==    by 0x4B853A2:
 std::allocator<geos::noding::SegmentString*> >&) (GeometryNoder.cpp:157)
 ==8512==    by 0x4B8584B: geos::noding::GeometryNoder::getNoded()
 (GeometryNoder.cpp:123)
 ==8512==    by 0x4B85A15:
 geos::noding::GeometryNoder::node(geos::geom::Geometry const&)
 (GeometryNoder.cpp:80)
 ==8512==    by 0x4865497: GEOSNode_r (geos_ts_c.cpp:2450)
 ==8512==    by 0x1092F0: main (in /home/raul/dev/public/geos/a.out)
 ==8512==
 ==8512== LEAK SUMMARY:
 ==8512==    definitely lost: 88 bytes in 1 blocks
 ==8512==    indirectly lost: 272 bytes in 7 blocks
 ==8512==      possibly lost: 0 bytes in 0 blocks
 ==8512==    still reachable: 1,152 bytes in 3 blocks
 ==8512==         suppressed: 0 bytes in 0 blocks
 ==8512== Reachable blocks (those to which a pointer was found) are not
 shown.
 ==8512== To see them, rerun with: --leak-check=full --show-leak-kinds=all
 ==8512==
 ==8512== For counts of detected and suppressed errors, rerun with: -v
 ==8512== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
 Hope this is useful. Let me know if you need any help.
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
