[geos-devel] [GEOS] #927: GEOSCoordSeq_isCCW() crashes with empty coordinate sequence
GEOS geos-trac at osgeo.org
Fri Sep 21 04:51:57 PDT 2018
 Reporter:  sirsigurd   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by Sergey Fedoseev <fedoseev.sergey@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"7a5f23ab15b45041271cc2c34852ea08689cfa3a/git" 7a5f23a/git]:
 #!CommitTicketReference repository="git"
 revision="7a5f23ab15b45041271cc2c34852ea08689cfa3a"
 Fix #927 -- Fixed crash in GEOSCoordSeq_isCCW() when used with empty
 coordseq.
Ticket URL: <https://trac.osgeo.org/geos/ticket/927#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
