[geos-devel] [GEOS] #929: Memory sanitizer warnings in GeometryFactory.cpp
GEOS geos-trac at osgeo.org
Fri Sep 28 07:18:23 PDT 2018
 Reporter:  Algunenano  |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.5.3
Component:  Default     |    Version:  3.5.0
 Severity:  Unassigned  |   Keywords:
 When running Postgis cunit tests using clang's (6.0.1) memory sanitizer
 (`-fsanitize=memory`) I get the following warning:
 Suite: buildarea
   Test: buildarea1 ...Uninitialized bytes in __interceptor_memcmp at
 offset 0 inside [0x7fffae24fa80, 4)
 ==19345==WARNING: MemorySanitizer: use-of-uninitialized-value
     #0 0x7f5ed6768c5f in std::char_traits<char>::compare(char const*, char
 const*, unsigned long) /build/gcc/src/gcc-build/x86_64-pc-linux-
 gnu/libstdc++-v3/include/bits/char_traits.h:310:25
     #1 0x7f5ed6768c5f in std::__cxx11::basic_string<char,
 std::char_traits<char>, std::allocator<char> >::compare(char const*) const
 gnu/libstdc++-v3/include/bits/basic_string.tcc:1424:37
     #2 0x7f5ed6892f40 in bool std::operator==<char,
 >(std::__cxx11::basic_string<char, std::char_traits<char>,
 std::allocator<char> > const&, char const*)
 /usr/include/c++/8.2.1/bits/basic_string.h:6075:35
     #3 0x7f5ed6892f40 in
 geos::geom::GeometryFactory::buildGeometry(std::vector<geos::geom::Geometry*,
 std::allocator<geos::geom::Geometry*> >*) const
 /usr/src/debug/geos/src/geom/GeometryFactory.cpp:664:16
     #4 0x7f5ed690dd48 in
 geos::operation::overlay::OverlayOp::computeOverlay(geos::operation::overlay::OverlayOp::OpCode)
 /usr/src/debug/geos/src/operation/overlay/OverlayOp.cpp:839:28
     #5 0x7f5ed690dee1 in
 geos::operation::overlay::OverlayOp::getResultGeometry(geos::operation::overlay::OverlayOp::OpCode)
 /usr/src/debug/geos/src/operation/overlay/OverlayOp.cpp:187:16
     #6 0x7f5ed690e281 in
 geos::operation::overlay::OverlayOp::overlayOp(geos::geom::Geometry
 const*, geos::geom::Geometry const*,
 /usr/src/debug/geos/src/operation/overlay/OverlayOp.cpp:93:30
     #7 0x7f5ed688d11f in
 geos::operation::overlay::overlayOp::operator()(geos::geom::Geometry
 const*, geos::geom::Geometry const*)
 /usr/src/debug/geos/src/geom/../../include/geos/operation/overlay/OverlayOp.h:388:44
     #8 0x7f5ed688d11f in std::unique_ptr<geos::geom::Geometry,
 std::default_delete<geos::geom::Geometry> >
 geos::geom::BinaryOp<geos::operation::overlay::overlayOp>(geos::geom::Geometry
 const*, geos::geom::Geometry const*, geos::operation::overlay::overlayOp)
 /usr/src/debug/geos/src/geom/../../include/geos/geom/BinaryOp.h:357:3
     #9 0x7f5ed688b16f in geos::geom::Geometry::Union(geos::geom::Geometry
 const*) const /usr/src/debug/geos/src/geom/Geometry.cpp:586:17
     #10 0x7f5ed691885d in
 geos::operation::geounion::CascadedPolygonUnion::unionActual(geos::geom::Geometry*,
 geos::geom::Geometry*)
 /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:370:36
     #11 0x7f5ed6919080 in
 geos::operation::geounion::CascadedPolygonUnion::unionOptimized(geos::geom::Geometry*,
 /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:236:27
     #12 0x7f5ed6919252 in
 geos::operation::geounion::CascadedPolygonUnion::unionTree(geos::index::strtree::ItemsList*)
 /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:162:23
     #13 0x7f5ed6919630 in
 geos::operation::geounion::CascadedPolygonUnion::Union()
 /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:151:21
     #14 0x7f5ed691983d in
 geos::operation::geounion::CascadedPolygonUnion::Union(geos::geom::MultiPolygon
 const*)
 /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:124:20
     #15 0x7f5ed71db6a8 in GEOSUnionCascaded_r
 /usr/src/debug/geos/capi/geos_ts_c.cpp:2497:43
     #16 0x7f5ed7332ed6 in LWGEOM_GEOS_buildArea
 /home/raul/dev/public/postgis/liblwgeom/lwgeom_geos.c:1124:8
     #17 0x7f5ed7333164 in lwgeom_buildarea
 /home/raul/dev/public/postgis/liblwgeom/lwgeom_geos.c:1155:7
     #18 0x55b755e00bfa in buildarea1
 /un/dev_public/postgis/liblwgeom/cunit/cu_buildarea.c:66:9
     #19 0x7f5ed6fb1117  (/usr/lib/libcunit.so.1+0x4117)
     #20 0x7f5ed6fb13b1  (/usr/lib/libcunit.so.1+0x43b1)
     #21 0x7f5ed6fb17b6 in CU_run_all_tests (/usr/lib/libcunit.so.1+0x47b6)
     #22 0x55b755e7f6b7 in main
 /un/dev_public/postgis/liblwgeom/cunit/cu_tester.c:177:13
     #23 0x7f5ed6c3c222 in __libc_start_main (/usr/lib/libc.so.6+0x24222)
     #24 0x55b755d7f0bd in _start
 (/un/dev_public/postgis/liblwgeom/cunit/.libs/lt-cu_tester+0x250bd)
 SUMMARY: MemorySanitizer: use-of-uninitialized-value /build/gcc/src/gcc-
 build/x86_64-pc-linux-gnu/libstdc++-v3/include/bits/char_traits.h:310:25
 in std::char_traits<char>::compare(char const*, char const*, unsigned
 long)
 I've tested 3.5 and 3.7 and both are affected.
 PR with the fix (for 3.7): https://github.com/libgeos/geos/pull/129
Ticket URL: <https://trac.osgeo.org/geos/ticket/929>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
