[geos-devel] [GEOS] #867: Regression in union algorithm between GEOS 3.6.1 and GEOS 3.6.2
geos-trac at osgeo.org
Fri Apr 12 14:50:51 PDT 2019
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 3.6.4
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
Further details on
[https://trac.osgeo.org/geos/changeset/1b24aed3c5ef4f972dd46ca46b6b389d02f38136/git
performance fix]:
For the test data in the [https://lists.osgeo.org/pipermail/postgis-
users/2019-April/043307.html 2019-Apr-11] thread the GEOS performance goes
from 150s to 111 s.
All unit tests pass, as does the #837 test case.
Ticket URL: <https://trac.osgeo.org/geos/ticket/867#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
