[geos-devel] Progress on #837 - TopologyException in UnaryUnion
Martin Davis
mtnclimb at gmail.com
Tue Apr 16 08:39:33 PDT 2019
I've also been thinking that for the case of unioning a polygonal coverage
there could be a much faster algorithm. Good to hear that you have an
implementation lined up. Can you work up a GEOS version based on your Java
code? (And if there are any extension needed to the Polygonizer to support
it, those can be in scope as well).
Are you thinking this would be exposed as a different PostGIS function (say
ST_UnionCoverage)?
I'm aconcerned about what happens if the input is not a valid polygonal
coverage. It can be very hard to "see" if a dataset is coverage-valid.
(For instance, the dataset of Norwegian poiygons that was posted recently
is *almost* a valid coverage, but out of it's 1.2 M segments has about 3
which cross slightly! It might be important to provide a IsCoverageValid
function, or perhaps even better a function to report the locations of
crossing segments. And ideally the ST_UnionCoverage function could report
an error on invalid input - but it's not clear how to do that efficiently,
which would defeat the purpose.
On Tue, Apr 16, 2019 at 8:21 AM Daniel Baston <dbaston at gmail.com> wrote:
> Either way, the union of a polygonal coverage is a common special case
> that would benefit from having its own algorithm. I implemented this for
> PostGIS a couple of years ago, though there didn't seem to be much interest
> at the time [1]. It's probably a better fit for GEOS anyway. I wrote a
> fairly ugly Java implementation several years ago [2] that I could re-do to
> take advantage of recent polygonizer improvements and bring into GEOS.
> Dan
> [1] https://lists.osgeo.org/pipermail/postgis-devel/2016-April/025784.html
> [2]
> https://github.com/dbaston/CoverageOp/tree/master/src/main/java/org/dbaston/coverageop
> On Tue, Apr 16, 2019 at 11:06 AM Martin Davis <mtnclimb at gmail.com> wrote:
>> That's good to know, Darafei. Can you provide a data example that we
>> can use for doing performance testing?
>> I'm not seeing that JTS buffer(0) is slower than union() on a random
>> triangulation. So perhaps either your dataset has some different
>> characteristic, or possibly GEOS buffer has different performance
>> characteristics to JTS.
>> On Tue, Apr 16, 2019 at 5:27 AM Darafei "Komяpa" Praliaskouski <
>> me at komzpa.net> wrote:
>>> Hello,
>>>> Ultimately I think the ideal approach is going to be abandoning
>>>> CascadedUnion and switch to a full union algorithm (which will essentially
>>>> be the same as running buffer(0). This should have very good performance.
>>> We're using PostGIS's ST_Union to dissolve a clipped TIN into a
>>> polygon. Current ST_Union implementation handles this measurably faster
>>> than ST_Buffer(ST_Collect(geom),0). Please keep this case in mind.
>>> Darafei Praliaskouski
>>> Support me: http://patreon.com/komzpa
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190416/13c9b1c1/attachment-0001.html>
