[geos-devel] [GEOS] #982: Postgis ST_ConcaveHull Runtime GEOS Problem?
geos-trac at osgeo.org
Fri Aug 2 12:35:45 PDT 2019
Reporter: tsw | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.7.0
Severity: Unassigned | Keywords:
A concave hull query with the attached data set under Postgresql 9.4 /
PostGIS 2.2 / Geos 3.5.0 runs in under a second.
The same query using the same data on Postgresql 9.6 / PostGIS 2.5.2 /
GEOS 3.7.1 is still running after 30 minutes.
I've also attached a perf top screen shot which to me implies this is a
GEOS problem.
Ticket URL: <https://trac.osgeo.org/geos/ticket/982>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
