[geos-devel] [GEOS] #983: Problem with 3.7 branch and shapely
geos-trac at osgeo.org
Mon Aug 12 04:52:52 PDT 2019
Reporter: aom | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.7.0
Severity: Unassigned | Keywords:
== problem
Using the git 3.7 branch (which I guess provides the current 3.7.x
distribution), the GEOSversion function returns:
``3.7.3-CAPI-1.11.3 3.7.2-6-ge1399c2``
Which makes the shapely installation fails, as it expect a "%d.%d.%d blah
%d.%d.%d" format and assert otherwise:
# pip install shapely --no-binary shapely
Collecting shapely
Using cached
https://files.pythonhosted.org/packages/a2/fb/7a7af9ef7a35d16fa23b127abee272cfc483ca89029b73e92e93cdf36e6b/Shapely-1.6.4.post2.tar.gz
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
File "/tmp/pip-install-2spcnx3e/shapely/setup.py", line 80, in
<module>
from shapely._buildcfg import geos_version_string, geos_version, \
File "/tmp/pip-install-2spcnx3e/shapely/shapely/_buildcfg.py", line
248, in <module>
geos_version_string, geos_version, geos_capi_version =
_geos_version()
242, in _geos_version
assert len(res) == 2, res
AssertionError: [('3', '7', '3'), ('1', '11', '3'), ('3', '7', '2')]
As a result, it is impossible to use that branch through the python
biding.
Although it could be considered an issue with the python bidings.
== To reproduce
(moonflash) 170135 13:26:30 [root at gemini ~]# more src/geosversion.c
#include <stdio.h>
extern char const *GEOSversion();
int main() {
printf("Got %s\n", GEOSversion());
return 0;
(moonflash) 170135 13:26:34 [root at gemini ~]# icc ./src/geosversion.c
/trinity/shared/OCA/softs/geos-3.7-intel19/lib/libgeos_c.so.1.11.3
/trinity/shared/OCA/softs/geos-3.7-intel19/lib/libgeos.so
(moonflash) 170135 13:26:38 [root at gemini ~]# ./a.out
Got 3.7.3-CAPI-1.11.3 3.7.2-6-ge1399c2
(moonflash) 170135 13:26:40 [root at gemini ~]#
== Possible cause
In that branch, the current definition of GEOSversion
const char* GEOSversion()
static char version[256];
sprintf(version, "%s " GEOS_REVISION, GEOS_CAPI_VERSION);
return version;
And GEOS_REVISION contains more than the git revision:
[alainm at gemini build]$ more geos_revision.h
#define GEOS_REVISION "3.7.2-6-ge1399c2"
[alainm at gemini build]$ more geos_revision.h.in
#define GEOS_REVISION "@GEOS_REVISION@"
Ticket URL: <https://trac.osgeo.org/geos/ticket/983>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
