[geos-devel] [GEOS] #982: Postgis ST_ConcaveHull Runtime GEOS Problem?
geos-trac at osgeo.org
Sun Aug 25 08:59:45 PDT 2019
Reporter: tsw | Owner: geos-devel@…
Type: defect | Status: reopened
Priority: major | Milestone:
Component: Default | Version: 3.7.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by komzpa):
@dbaston PostGIS is calling GEOSUnion in natural way as part of higher
level algorithm.
Single GEOSUnaryUnion call is working unexpectedly slow. This manifests as
slow PostGIS. That manifestation is problem of PostGIS. The slowness of
GEOSUnaryUnion is GEOS problem, will be there whether ST_ConcaveHull is
rewritten or not, and this ticket has everything to reproduce it.
If GEOS is not concerned of performance of overlay ops then this ticket
can be closed together with #867. I hope this is not the case.
Ticket URL: <https://trac.osgeo.org/geos/ticket/982#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
