[geos-devel] [GEOS] #982: Postgis ST_ConcaveHull Runtime GEOS Problem?
geos-trac at osgeo.org
Sun Aug 25 09:49:03 PDT 2019
Reporter: tsw | Owner: geos-devel@…
Type: defect | Status: reopened
Priority: major | Milestone:
Component: Default | Version: 3.7.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
But this has nothing to do with concave hull, in the end? The issue is
that you'd like the unary union of many lines to be faster, no? Would that
not be better captured in a ticket that leaves PostGIS, concave hull, and
all other noise out of it?
Ticket URL: <https://trac.osgeo.org/geos/ticket/982#comment:13>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
