[geos-devel] [GEOS] #982: Postgis ST_ConcaveHull Runtime GEOS Problem?
geos-trac at osgeo.org
Mon Aug 26 17:38:58 PDT 2019
Reporter: tsw | Owner: geos-devel@…
Type: defect | Status: reopened
Priority: major | Milestone:
Component: Default | Version: 3.7.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
Now that I've looked at the data in this test case, I can see that this
dataset is absolutely a worst-case scenario for union. The reason is that
there are so many intersections between the lines, it is going to produce
on the order of O(n^2) node points. This means the noding process has to
run in slow O(n^2) time. Also, memory usage is going to be very large.
So this is an example of where using Union within the Concave Hull
algorithm is not a good idea.
Ticket URL: <https://trac.osgeo.org/geos/ticket/982#comment:17>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
