[geos-devel] [GEOS] #962: GEOSNode is much slower that	GEOSUnaryUnion
    geos-trac at osgeo.org
    Mon Aug 26 17:40:02 PDT 2019
 Reporter:  komzpa      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 I think the tickets referred to in the UnaryUnion comments suggest that
 the cascaded union helps robustness by unioning nearby lines together
 (which supposedly helps because of common bit removal.) I think it's
 becoming off-topic for this ticket but we can discuss at
 https://github.com/libgeos/geos/pull/213
Ticket URL: <https://trac.osgeo.org/geos/ticket/962#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
