[geos-devel] [GEOS] #702: OverlayOp takes mover 20 minutes when a polygon with over a million holes is involved
geos-trac at osgeo.org
Tue Aug 27 08:11:16 PDT 2019
is involved
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: Default | Version: 3.4.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
strk, do you still have these inputs after 5 years, and do you want to see
if there is an improvement following this:
https://github.com/libgeos/geos/pull/141 ?
Ticket URL: <https://trac.osgeo.org/geos/ticket/702#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
