[geos-devel] [GEOS] #840: PointOnSurface strange behavior
geos-trac at osgeo.org
Mon Feb 11 12:01:10 PST 2019
Reporter: sbe | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.6.4
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: pointOnSurface |
Comment (by mdavis):
The reason for the discrepancy in computed interior points is due to how
the Interior Point in Area algorithm works. It is designed to quickly
find a point lying in the polygon interior, and is optimized for
performance, not quality of point location. The two polygons just happen
to be different enough that the algorithm chooses a different "band" of
the polygon to place the interior point.
If a better quality location is desired, then there are other (less
performant) algorithms to do this (e.g. computing the
LargestInscribedCircle AKA Pole of Inaccessibility). I'm hoping to bring
this to GEOS soon. Or perhaps compute both the centroid and interior
point and pick the best one (= furthest from polygon boundary AND in the
interior)
@mloskot: the InteriorPointArea algorithm is deterministic, so it does
actually return the same point each time it is called.
Finally, there's a big performance improvement available for the
InteriorPointArea algorithm, and that should land soon in GEOS.
Ticket URL: <https://trac.osgeo.org/geos/ticket/840#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
