[geos-devel] [GEOS] #950: Regress failures on debbie and gitlab-ci on InteriorPointAreaPerfTest
geos-trac at osgeo.org
Mon Feb 18 01:49:45 PST 2019
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.8.0
Component: Default | Version: master
Severity: Critical | Keywords:
The other bots seem to be okay, but both debbie and gitlab-ci are failing
with the same error as a result of this commit:
Commit 314960229dc44d5379aed57aed94c5190384c883 by gitea
Add InteriorPoint Area perf test, Profile enhancement (#63)
Error is
https://debbie.postgis.net/job/GEOS_Master/472/consoleFull
https://gitlab.com/geos/libgeos/-/jobs/162419404
make[3]: Entering directory '/var/lib/jenkins/workspace/geos/branches/3.8'
! find . -name '*.cpp' -o -name '*.h' | \
grep -v tests/xmltester/tinyxml | \
grep -v include/geos/algorithm/ttmath | \
xargs grep -n '[[:space:]]$'
./tests/perf/algorithm/InteriorPointAreaPerfTest.cpp:53:
std::unique_ptr<Polygon> sinePoly =
./tests/perf/algorithm/InteriorPointAreaPerfTest.cpp:83: void
./tests/perf/algorithm/InteriorPointAreaPerfTest.cpp:87: cout <<
"SineStar: origin: ("
./tests/perf/algorithm/InteriorPointAreaPerfTest.cpp:88: <<
ORG_X << ", " << ORG_Y
./tests/perf/algorithm/InteriorPointAreaPerfTest.cpp:90: <<
" # arms: " << N_ARMS
./tests/perf/algorithm/InteriorPointAreaPerfTest.cpp:91: <<
" arm ratio: " << ARM_RATIO
make[3]: *** [Makefile:933: check-local] Error 1
make[3]: Leaving directory '/var/lib/jenkins/workspace/geos/branches/3.8'
make[2]: *** [Makefile:771: check-am] Error 2
make[2]: Leaving directory '/var/lib/jenkins/workspace/geos/branches/3.8'
make[1]: *** [Makefile:477: check-recursive] Error 1
make[1]: Leaving directory '/var/lib/jenkins/workspace/geos/branches/3.8'
make: *** [Makefile:773: check] Error 2
Build step 'Execute shell' marked build as failure
IRC notifier plugin: Sending notification to: #postgis-activity
Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/geos/ticket/950>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
