[geos-devel] [gitlab at mg.gitlab.com: libgeos | Pipeline #48453688 has failed for master | edc36747]
Martin Davis
mtnclimb at gmail.com
Thu Feb 21 10:43:45 PST 2019
The most recent pipeline passes:
https://gitlab.com/geos/libgeos/pipelines/48455803
The previous pipeline failed because of a missing std:: declaration. That
caused several of the bots to fail, so it was pretty visibl.
https://gitlab.com/geos/libgeos/pipelines/48453688
So seems like this isn't a problem?
On Thu, Feb 21, 2019 at 12:46 AM Sandro Santilli <strk at kbt.io> wrote:
> Martin, can you please take a look at why gitlab CI fails ?
> I'm not sure it has to do with any of your recent commits.
> It would be great if gitlab-ci could be configured to notify the
> mailing list instead of just me ...
> ----- Forwarded message from GitLab <gitlab at mg.gitlab.com> -----
> Date: Wed, 20 Feb 2019 21:01:54 +0000
> From: GitLab <gitlab at mg.gitlab.com>
> Subject: libgeos | Pipeline #48453688 has failed for master | edc36747
> Reply-To: GitLab <noreply at gitlab.com>
> List-Id: geos/libgeos <381840.libgeos.geos.gitlab.com>
> Your pipeline has failed.
> Project: libgeos ( https://gitlab.com/geos/libgeos )
> Branch: master ( https://gitlab.com/geos/libgeos/commits/master )
> Commit: edc36747 (
> https://gitlab.com/geos/libgeos/commit/edc36747409058cb10aeb8d9505d280dfbfcf697
> Commit Message: Port JTS InteriorPointArea improvements
> Commit Author: Martin Davis
> Pipeline #48453688 ( https://gitlab.com/geos/libgeos/pipelines/48453688 )
> triggered by Sandro Santilli ( https://gitlab.com/strk )
> had 1 failed build.
> Job #164870085 ( https://gitlab.com/geos/libgeos/-/jobs/164870085 )
> Stage: test
> Trace: Makefile:595: recipe for target 'all-recursive' failed
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory '/builds/geos/libgeos/src'
> Makefile:477: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory '/builds/geos/libgeos'
> Makefile:424: recipe for target 'all' failed
> make: *** [all] Error 2
> section_end:1550696510:build_script
> [0Ksection_start:1550696510:after_script
> [0Ksection_end:1550696512:after_script
> [0Ksection_start:1550696512:upload_artifacts_on_failure
> [0Ksection_end:1550696513:upload_artifacts_on_failure
> [0K [31;1mERROR: Job failed: exit code 1
> [0;m
> You're receiving this email because of your account on gitlab.com.
> ----- End forwarded message -----
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190221/e711602e/attachment.html>
