[geos-devel] [GEOS] #955: Reducing number of configurations in appveyor.yml
GEOS geos-trac at osgeo.org
Fri Feb 22 06:13:28 PST 2019
 Reporter:  rouault     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 We've had lots of build errors that were specific to particular MSVC
 versions and architectures, so I'd be hesitant to remove these in the name
 of efficiency. (One can always reduce the "turnaround" by deciding to
 ignore some of the configurations.)
 We could remove the NMake configuration though, as I believe we've agreed
 not to support that.
Ticket URL: <https://trac.osgeo.org/geos/ticket/955#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
