[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Mon Feb 25 11:19:08 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by rouault):
Replying to [comment:12 mdavis]:
> That's a workflow hassle, to have to make a PR and then iterate on that
to get the code right.
That's the whole point of the github/gitlab/etc + continuous integration
workflows... A lot of project work like that. For example, I had to fix
the Windows build because there was an earlier commit made in master which
broke it.
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:13>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
