[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Mon Feb 25 11:43:49 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
I would say policy is not to merge if a bot is red. If the bot is wrong
then it needs to be fixed.
Although if a bot is badly broken (like Bessies are now) then might have
to ignore them and carry on.
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:18>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
