[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Mon Feb 25 13:16:28 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
Ok, that sounds good enough to catch most coding errors. And now that the
badges are fixed the GH CI will be a bit more visible.
So I guess the best practice is to always make a GH PR for any non-trivial
change. Would be good to document this.
This still only really helps if Werror is in place, right?
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:23>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
