[geos-devel] JTS TestBuilder for geometry visualization
Even Rouault
even.rouault at spatialys.com
Wed Feb 27 11:34:26 PST 2019
Martin,
thanks for the hint. Let me mention alternatives :-)
For those who prefer QGIS, I suggest the QuickWKT plugin where you can paste
WKT or WKB.
If you select a feature (existing, or just created), copy and paste it in a
text application, you will get the WKT.
Otherwise (limited to WKT), you may also create a simple .csv file
id,WKT
1,"your WKT"
2,"your WKT"
and open it with QGIS. (the WKT colum name is critical so that the column is
recognized as a geometry)
Even
> Just in case anyone isn't familiar with it, the JTS TestBuilder is a Java
> GUI application which might be useful for some aspects of GEOS
> development. In particular, it's handy for creating and viewing geometry
> test cases. You can draw and edit geometry, and capture the results as WKT
> or WKB (and several other formats as well). You can also drop an entire
> JTS/GEOS Test XML file in order to view all the cases in the file.
> It's available as a fat jar from the JTS Releases page:
> https://github.com/locationtech/jts/releases
> Docs are limited, but most things have tooltips. With suitable
> encouragement I might even get around to writing a proper manual one day...
http://www.spatialys.com
