[geos-devel] JTS TestBuilder for geometry visualization
Martin Davis mtnclimb at gmail.com
Thu Feb 28 09:26:19 PST 2019
That's slick.  For geojson.io does the data have to be in geodetic?
On Thu, Feb 28, 2019 at 6:00 AM Darafei "Komяpa" Praliaskouski <
me at komzpa.net> wrote:
> Hi,
> I use Meta -> Load WKT string on geojson.io. Nothing to install, just a
> browser tab.
> On Wed, Feb 27, 2019 at 11:01 PM Martin Davis <mtnclimb at gmail.com> wrote:
>> That's good to know too.
>> These would be good to have in the wiki (if not there already).
>> On Wed, Feb 27, 2019 at 11:34 AM Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> Martin,
>>> thanks for the hint. Let me mention alternatives :-)
>>> For those who prefer QGIS, I suggest the QuickWKT plugin where you can
>>> paste
>>> WKT or WKB.
>>> If you select a feature (existing, or just created), copy and paste it
>>> in a
>>> text application, you will get the WKT.
>>> Otherwise (limited to WKT), you may also create a simple .csv file
>>> id,WKT
>>> 1,"your WKT"
>>> 2,"your WKT"
>>> and open it with QGIS. (the WKT colum name is critical so that the
>>> column is
>>> recognized as a geometry)
>>> Even
>>> > Just in case anyone isn't familiar with it, the JTS TestBuilder is a
>>> Java
>>> > GUI application which might be useful for some aspects of GEOS
>>> > development.  In particular, it's handy for creating and viewing
>>> geometry
>>> > test cases.  You can draw and edit geometry, and capture the results
>>> as WKT
>>> > or WKB (and several other formats as well).  You can also drop an
>>> entire
>>> > JTS/GEOS Test XML file in order to view all the cases in the file.
>>> > It's available as a fat jar from the JTS Releases page:
>>> > https://github.com/locationtech/jts/releases
>>> > Docs are limited, but most things have tooltips.  With suitable
>>> > encouragement I might even get around to writing a proper manual one
>>> day...
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190228/26cb6095/attachment.html>
