[geos-devel] [GEOS] #976: Voronoi polygons robustness issue
GEOS geos-trac at osgeo.org
Tue Jul 16 08:31:12 PDT 2019
 Reporter:  komzpa      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 `long double` is also not the same as `DoubleDouble` even if it available.
 Given that GEOS is already set up to use the `ttmath` library for
 extended-precision, I can't see a reason not to use it.
Ticket URL: <https://trac.osgeo.org/geos/ticket/976#comment:17>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
