[geos-devel] [GEOS] #978: UnaryUnion topology exception
geos-trac at osgeo.org
Wed Jul 17 12:10:11 PDT 2019
Reporter: komzpa | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone:
Component: Default | Version: 3.7.0
Severity: Unassigned | Resolution: invalid
Keywords: |
Comment (by mdavis):
Yes, if I understand it correctly.
UnaryUnion of B works correctly in JTS. But I do see some very close
coordinates in the output though, which might mean that GEOS is hitting a
robustness problem during the sequence of unions somewhere in UnaryUnion.
The upcoming OverlayNG should fix this kind of problem.
Ticket URL: <https://trac.osgeo.org/geos/ticket/978#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
