[geos-devel] [GEOS] #973: Polygon clipping and validation over integer coordinates
geos-trac at osgeo.org
Mon Jun 10 06:06:51 PDT 2019
Reporter: Algunenano | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: minor | Milestone: GEOS Fund Me
Component: Default | Version: master
Severity: Feature Request | Keywords:
Comes from https://trac.osgeo.org/geos/ticket/959
To generate MVT geometries, Postgis transforms the input geometries into
the MVT coordinate system (coordinates aren't absolute, but relative to
the tile, the y axis is reverted with 0,0 being the top left, and only
integer values can be used), clips them to the tile if required and
transforms them to have a valid output.
Doing this using GEOS has proven to be extremely hard for several reasons:
- `GEOSClipByRect` is fast, but only guarantees a valid output on valid
input. `GEOSIntersection` is order of magnitude slower and also requires
valid input. Since making a polygon valid is an even slower operation,
there are several hacks trying to detect the issue and work around the
limits of `GEOSClipByRect`.
- Both `GEOSClipByRect` and `GEOSMakeValid` (which Postgis currently
doesn't use, but the issue is the same) can add new points that require
double precision (not integers), which then require a new operation and
rechecking validation. You can guess that the performance in those cases
is terrible. You can even get a polygon that is valid, becomes invalid
when using int precision, becomes valid when calling MakeValid but using
doubles, then invalid with ints and you can keep going ad eternum.
Currently, I've introduced an extra library in Postgis, Wagyu, to deal
with this since it provides fast clipping and, more importantly, fast
polygon validation with int coordinates; but ideally this could be
provided by GEOS to reduce the dependencies.
I've talked a couple of times with @mdavis about this, but I wanted to
fill the ticket and have it documented somewhere.
Ticket URL: <https://trac.osgeo.org/geos/ticket/973>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
