[geos-devel] [GEOS] #959: Reversed result in GEOSClipByRect
GEOS geos-trac at osgeo.org
Mon Mar 11 08:36:18 PDT 2019
 Reporter:  Algunenano   |      Owner:  geos-devel@…
     Type:  defect       |     Status:  new
 Priority:  major        |  Milestone:  3.5.2
Component:  Default      |    Version:  3.5.0
 Severity:  Significant  |   Keywords:
 When passing the following **invalid** geometry to GEOSClipByRect, the
 result of the clipping is reversed (you get the part of the box that
 doesn't intersects with the geometry).
 template<> template<> void object::test<14>
     const char* wkt = "POLYGON((680 2050,682 2050,683 2054,686 2059,690
 2061,694 2062,697 2065,699 2071,700 2080,701 2081,702 2081,703 2082,702
 2083,701 2084,701 2085,699 2086,700 2086,699 2086,698 2085,699 2085,695
 2083,689 2083,687 2083,685 2085,679 2083,677 2081,677 2078,673 2069,668
 2062,667 2062,666 2062,665 2060,667 2058,667 2056,665 2055,666 2055,666
 2054,667 2053,666 2052,667 2050,668 2050,670 2054,672 2052,673 2053,674
 2052,676 2050,679 2050,680 2050))";
     geom1_ = GEOSGeomFromWKT(wkt);
     geom2_ = GEOSClipByRect(geom1_, -8, -8, 2056, 2056);
     isEqual(geom2_, "POLYGON((665 2055,667 2056,684.2 2056,683 2054,682
 2050,680 2050,679 2050,676 2050,674 2052,673 2053,672 2052,670 2054,668
 2050,667 2050,666 2052,667 2053,666 2054,666 2055,665 2055))");
 This is affecting Postgis, both in ST_ClipByBox2d and ST_AsMVTGeom
 (although it has a hack to try to detect this and drop the geometry
 completely).
Ticket URL: <https://trac.osgeo.org/geos/ticket/959>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
