[geos-devel] [GEOS] #960: Exception when creating geometry buffer
GEOS geos-trac at osgeo.org
Tue Mar 19 10:13:39 PDT 2019
 Reporter:  allenkim0129               |       Owner:  geos-devel@…
     Type:  defect                     |      Status:  new
 Priority:  blocker                    |   Milestone:
Component:  Default                    |     Version:  3.6.2
 Severity:  Unassigned                 |  Resolution:
 Keywords:  Buffer, TopologyException  |
Comment (by mdavis):
 You should note that buffering with CAP_FLAT produces a very poor buffer
 outline when the buffer distance is large relative to the geometry (as in
 this case). In fact, this should probably not be used at all in this case.
Ticket URL: <https://trac.osgeo.org/geos/ticket/960#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
