[geos-devel] RFC 9: Restore C++ API as public API
Andrew Bell andrew.bell.ia at gmail.com
Fri May 17 05:21:20 PDT 2019
But this seems like a choice for library users. From a packaging
perspective, why isn't the issue one of API rather than binary
compatibility? Are you not rebuilding packages?
On Fri, May 17, 2019, 6:30 AM Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 5/17/19 1:14 PM, Andrew Bell wrote:
> > Why is this? There are many libraries that have C++ interfaces.
> Which also have difficulty providing a stable ABI. One that doesn't
> change the symbols it exports with the new compiler releases, etc.
> Having a stable C ABI is a major plus for any project that uses C++ in
> its codebase, it makes transitions to new releases much easier. A core
> library like GEOS have many projects that require it, some are actively
> maintained and implement changes quicky, others don't. And these make
> life suck for distributions where all the projects need to be integrated
> to work with the same version of GEOS.
> > On Thu, May 16, 2019, 11:37 PM Sebastiaan Couwenberg <sebastic at xs4all.nl
> > wrote:
> >> On 5/16/19 11:28 PM, Mateusz Loskot wrote:
> >>> I'd like propose to effectively revert the RFC 6:
> >>> https://trac.osgeo.org/geos/wiki/RFC9
> >> Please don't. We'll get more projects like OSSIM that break with new
> >> GEOS releases, this causes significant delays before the new release can
> >> be included in distributions where lots of projects depend on GEOS
> >> (which all need to build with the new release).
> Kind Regards,
> Bas
>  GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190517/a8d731c0/attachment.html>
