[geos-devel] [GEOS] #969: errors in docs for unary union
    geos-trac at osgeo.org
    Fri May 17 05:48:43 PDT 2019
 Reporter:  kthujvu        |      Owner:  geos-devel@…
     Type:  defect         |     Status:  new
 Priority:  trivial        |  Milestone:
Component:  Documentation  |    Version:  3.6.2
 Severity:  Unassigned     |   Keywords:  documentation
 I noticed some typos on
 https://geos.osgeo.org/doxygen/classgeos_1_1operation_1_1geounion_1_1UnaryUnionOp.html
 "merging al identical" should be "merging all identical"
 Duplicate plural "s" for linked things: Polygonss, Pointss
 All links in the "Detailed Description" point to the page itself.
 "Member Function Documentation" once says "POINT EMPTY" will be returned
 if no input geometry, then says "empty GEOMETRYCOLLECTION". It should be
 the latter.
 No patch from me because that's too complicated on this setup.
Ticket URL: <https://trac.osgeo.org/geos/ticket/969>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
