[geos-devel] [GEOS] #970: CMAke broken on winnie and appveyor (mingw64, VS) and travis (was: CMAke broken on winnie and appveyor (mingw64, VS))
GEOS geos-trac at osgeo.org
Sat May 18 13:06:27 PDT 2019
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.8.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by robe):
 Just checked even our happy go luck travis cmake runs are failing.
 -- GEOS: C API soversion 11
 -- GEOS: JTS port 1.13.0
 -- GEOS: Require C++11
 -- GEOS: Developer mode enabled
 CMake Error at tests/xmltester/CMakeLists.txt:15 (add_executable):
   add_executable called with incorrect number of arguments
 CMake Error at tests/xmltester/CMakeLists.txt:16 (target_sources):
   Cannot specify sources for target "test_xmltester" which is not built by
   this project.
 CMake Error at tests/xmltester/CMakeLists.txt:23 (target_link_libraries):
   Cannot specify link libraries for target "test_xmltester" which is not
   built by this project.
Ticket URL: <https://trac.osgeo.org/geos/ticket/970#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
