[geos-devel] [GEOS] #971: @GEOS_VERSION@ not being replaced
geos-trac at osgeo.org
Tue May 21 19:08:24 PDT 2019
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: Default | Version: master
Severity: Critical | Keywords:
I just noticed that debbie's postgis builds started failing recently.
Looks like the geos @GEOS_VERSION@ is not being replaced.
Might be something I need to change but was fine 5 days ago.
WARNING: You have set the --prefix to
'/var/lib/jenkins/workspace/pg/rel/pg11w64'. But we mostly
ignore the --prefix. For your info, using the values determined from
/var/lib/jenkins/workspace/pg/rel/pg11w64/bin/pg_config we will be
installing:
* postgis shared library in
/var/lib/jenkins/workspace/pg/rel/pg11w64/lib
* postgis SQL files in
/var/lib/jenkins/workspace/pg/rel/pg11w64/share/postgresql/contrib/postgis-3.0
* postgis executables in /var/lib/jenkins/workspace/pg/rel/pg11w64/bin
checking for xml2-config... /usr/bin/xml2-config
checking libxml/tree.h usability... yes
checking libxml/tree.h presence... yes
checking for libxml/tree.h... yes
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
checking libxml/xpath.h usability... yes
checking libxml/xpath.h presence... yes
checking for libxml/xpath.h... yes
checking libxml/xpathInternals.h usability... yes
checking libxml/xpathInternals.h presence... yes
checking for libxml/xpathInternals.h... yes
checking for xmlInitParser in -lxml2... yes
Using user-specified geos-config file:
/var/lib/jenkins/workspace/geos/rel-3.8w64/bin/geos-config
checking GEOS version... @GEOS_VERSION@
configure: error: PostGIS requires GEOS >= 3.6.0
Build step 'Execute shell' marked build as failure
An attempt to send an e-mail to empty list of recipients, ignored.
Triggering a new build of PostgreSQL stop
Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/geos/ticket/971>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
