[geos-devel] [GEOS] #1002: assertion failures with VS2017 / VS2019
GEOS geos-trac at osgeo.org
Mon Nov 4 06:26:18 PST 2019
 Reporter:  dbaston     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.8.1
Component:  Default     |     Version:  3.8.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by Daniel Baston <dbaston@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"3fc652822ef3a825784919423d636c9584dbd2ba/git" 3fc6528/git]:
 #!CommitTicketReference repository="git"
 revision="3fc652822ef3a825784919423d636c9584dbd2ba"
 Avoid access past end of vector
 In most configurations this access would be optimized out (as it is
 never used) but this is not always the case.
 Fixes #1002
Ticket URL: <https://trac.osgeo.org/geos/ticket/1002#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
