[geos-devel] Can't build using 3.8.0rc1 tarball and CMake
Regina Obe
lr at pcorp.us
Thu Oct 3 07:18:54 PDT 2019
I'm having some trouble trying to build 3.8.0rc1 using CMake and the
http://download.osgeo.org/geos/geos-3.8.0rc1.tar.bz2 tarball .
I don't have the same issue building from git master.
-- GEOS: Using default build type: Release
-- GEOS: Run-time output: C:/Projects/sources/build/bin
-- GEOS: Archives output: C:/Projects/sources/build/lib
-- The C compiler identification is GNU 8.1.0
-- The CXX compiler identification is GNU 8.1.0
-- Check for working C compiler: C:/ming64gcc81/mingw64/bin/gcc.exe
-- Check for working C compiler: C:/ming64gcc81/mingw64/bin/gcc.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/ming64gcc81/mingw64/bin/g++.exe
-- Check for working CXX compiler: C:/ming64gcc81/mingw64/bin/g++.exe --
works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- GEOS: Version 3.8.0rc1
-- GEOS: C API Version 1.13.1
-- GEOS: JTS port 1.13.0
-- GEOS: Require C++11
CMake Error at CMakeLists.txt:267 (add_subdirectory):
The source directory
C:/Projects/sources/geos-3.8.0rc1/doc
does not contain a CMakeLists.txt file.
CMake Error: File C:/Projects/sources/geos-3.8.0rc1/tools/geos-config.cmake
does not exist.
CMake Error at tools/CMakeLists.txt:15 (configure_file):
configure_file Problem configuring file
-- GEOS: Configured 'dist' target
CMake Warning at CMakeLists.txt:375 (find_package):
By not providing "FindMakeDistCheck.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"MakeDistCheck", but CMake did not find one.
Could not find a package configuration file provided by "MakeDistCheck"
with any of the following names:
MakeDistCheckConfig.cmake
makedistcheck-config.cmake
Add the installation prefix of "MakeDistCheck" to CMAKE_PREFIX_PATH or set
"MakeDistCheck_DIR" to a directory containing one of the above files. If
"MakeDistCheck" provides a separate development package or SDK, be sure it
has been installed.
CMake Error at CMakeLists.txt:376 (AddMakeDistCheck):
Unknown CMake command "AddMakeDistCheck".
-- Configuring incomplete, errors occurred!
See also "C:/Projects/sources/build/CMakeFiles/CMakeOutput.log".
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'test'. Stop.
make: *** No rule to make target 'check'. Stop.
C:\ming64gcc81\mingw64\bin\strip.exe:
'C:/ming64gcc81/projects/geos/rel-3.8.0rc1w64gcc81/bin/*.dll': No such file
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20191003/962542d1/attachment.html>
