[geos-devel] [GEOS] #994: Segfault in UnaryUnionOp (::buildGeometry, something with C++ strings!)
geos-trac at osgeo.org
Tue Oct 8 06:49:08 PDT 2019
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Changes (by dbaston):
* Attachment "issue-geos-994.xml" added.
failing xml test
Ticket URL: <https://trac.osgeo.org/geos/ticket/994>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
