[geos-devel] [GEOS] #994: Segfault in UnaryUnionOp (::buildGeometry, something with C++ strings!)
GEOS geos-trac at osgeo.org
Tue Oct 8 07:23:41 PDT 2019
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by Algunenano):
 > Raúl, did you use a Docker file or similar to run the QGIS tests against
 GEOS master?
 No, I've got GEOS master installed in the system and built QGIS from
 source. Since it's linked dynamically I've replaced the GEOS package with
 one that printed the input to a file
 (https://github.com/Algunenano/geos/commit/a81133bd808e40d3a31bc60bce53a20aa1aec8fe)
Ticket URL: <https://trac.osgeo.org/geos/ticket/994#comment:15>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
