[geos-devel] [GEOS] #994: Segfault in UnaryUnionOp (::buildGeometry, something with C++ strings!)
GEOS geos-trac at osgeo.org
Tue Oct 8 08:22:50 PDT 2019
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by strk):
 I confirm the fix in master branch.
 And I confirm my view on 3.6 was wrong, because `make install` of
 updated GEOS did not fix the crash at first, but required me to
 rm -f /usr/local/libgeos* first
 I guess it was an effect of the bug fixed with
 [d47ea8c428da1ed4957916c49268740b362db9fb/git]
Ticket URL: <https://trac.osgeo.org/geos/ticket/994#comment:18>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
