[geos-devel] GEOS 3.8.0 RC3
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 8 11:17:57 PDT 2019
This all seems like good fodder for 3.8.1
P
> On Oct 8, 2019, at 11:15 AM, rmrodriguez at carto.com wrote:
> Hi,
> I've run scan-build against the project and it shows ~30 issues,
> some minor and some important.
> I've created a PR addressing them (https://github.com/libgeos/geos/pull/238)
> but there is still 12 more in case someone wants to have a look before
> me (I'll try
> to finish with them tomorrow).
> On Tue, Oct 8, 2019 at 7:42 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> Hi all GEOS people,
>> *Especially packagers...* (This package fixes one last regression
>> noticed in QGIS.)
>> 3.8.0 will be released in 48 hours if no blockers are raised.
>> In support of that we would like
>> your help testing out the final project. You’ll find that there are
>> lots of performance improvements, we hope, and improved reliability in
>> common operations.
>> http://download.osgeo.org/geos/geos-3.8.0rc2.tar.bz2
>> Please report any issues you find in building or running tests on the
>> GEOS ticket tracker https://trac.osgeo.org/geos/ or to this list.
>> - New things:
>> - CAPI: GEOSBuildArea (#952, Even Rouault)
>> - CAPI: GEOSMakeValid (#952, Even Rouault)
>> - CAPI: GEOSPolygonize_valid (#727, Dan Baston)
>> - CAPI: GEOSCoverageUnion (Dan Baston)
>> - CAPI: GEOSCoordSeq_setXY, GEOSCoordSeq_setXYZ,
>> GEOSCoordSeq_getXY, GEOSCoordSeq_getXYZ (Dan Baston)
>> - CAPI: GEOSMinimumBoundingCircle (#735)
>> - CAPI: GEOSGeom_createPointFromXY (Dan Baston)
>> - Improvements:
>> - Improve overall performance by reducing of heap allocations (Dan Baston)
>> - Improve performance and robustness of GEOSPointOnSurface (Martin Davis)
>> - Improve performance of GEOSPolygonize for cases with many potential
>> holes (#748, Dan Baston)
>> - Support extended precision calculations (ttmath) and port JTS
>> improvements related to extended precision (Paul Ramsey, Mateusz Loskot)
>> - Improve performance of GEOSPolygonize for cases with many or complex
>> shells (Dan Baston, Martin Davis)
>> - Improve performance of Delaunay triangulations / Voronoi Diagrams
>> (Dan Baston)
>> - Improve performance of prepared geometry operations (Dan Baston)
>> - Improve robustness of Delaunay triangulations (Paul Ramsey, Martin Davis)
>> - Improve performance of unary union for lines (Dan Baston)
>> - Improve general predicate, overlay, and buffer performance (Dan
>> Baston, Paul Ramsey)
>> - Improve cascaded union performance (Paul Ramsey, Martin Davis)
>> - Allocate default GeometryFactory singleton on the stack (Sandro Mani)
>> - Harmonize XML tests with JTS and harmonize cmake/autoconf
>> test running (Paul Ramsey)
>> - CMake modernization (Mateusz Loskot, Paul Ramsey, Dan Baston)
>> - Return unique_ptr from most methods that produce a new geometry (Dan Baston)
>> - Changes:
>> - Constructive geometry functions in CAPI now preserve SRID
>> of input arguments in output (#896)
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
> Raúl Marín Rodríguez
> carto.com
