[geos-devel] [GEOS] #1002: assertion failures with VS2017 / VS2019
geos-trac at osgeo.org
Wed Oct 23 18:02:38 PDT 2019
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.8.1
Component: Default | Version: 3.8.0
Severity: Unassigned | Keywords:
Reported by Asa Packer:
> If I build in Debug mode, with either VS2017 or VS2019, I get tons of
assertion failures when I do ctest. They all come from line 115 of
MonotoneChainBuilder.cpp, which on the last time through the loop causes
an access of an element one past the end of a std::vector. Even if I
ignore the assertion failures, the tests show as fails because the C
runtime considers these to be fatal errors.
Proposed fix:
--- geos-3.8.0/src/index/chain/MonotoneChainBuilder.cpp
+++ geos-3.8.0/src/index/chain/MonotoneChainBuilder.cpp
@@ -111,8 +111,10 @@
++last;
- prev = curr;
- curr = &pts[last];
+ if (last < npts) {
+ prev = curr;
+ curr = &pts[last];
Ticket URL: <https://trac.osgeo.org/geos/ticket/1002>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
