[geos-devel] 3.8.0 problems building on Windows
Daniel Baston dbaston at gmail.com
Wed Oct 23 18:13:01 PDT 2019
Hello Asa,
Thank you for the reports. I ticketed the assertion failure issue at:
https://trac.osgeo.org/geos/ticket/1002
I'm not sure why the CMake version check for MSVC needs to be a fatal
error, since we're not using any features from CMake > 3.8. Does anyone
object to changing this?
Dan
On Mon, Oct 21, 2019 at 3:14 PM Asa Packer <APacker at biosonicsinc.com> wrote:
> Hi,
> I just started working with version 3.8.0, trying to build it on Windows.
> I ran into two issues:
>    1. Out of the box I can’t build geos 3.8.0 with a fully-updated Visual
>    Studio 2017, because geos wants cmake 3.13 and VS2017 only has 3.12.  If I
>    change line 22 of the top-level CMakeLists.txt to require only 3.12, then I
>    can build fine in Release mode, either 32 or 64 bit, and ctest shows no
>    failures.
>    2. If I build in Debug mode, with either VS2017 or VS2019, I get tons
>    of assertion failures when I do ctest.  They all come from line 115 of
>    MonotoneChainBuilder.cpp, which on the last time through the loop causes an
>    access of an element one past the end of a std::vector.  Even if I ignore
>    the assertion failures, the tests show as fails because the C runtime
>    considers these to be fatal errors.
> Below is a patch that fixes these issues.  Are these reasonable
> workarounds?
> Thanks!
> Asa
> Index: geos-3.8.0/CMakeLists.txt
> --- geos-3.8.0/CMakeLists.txt
> +++ geos-3.8.0/CMakeLists.tt
> @@ -19,7 +19,7 @@
> # Require CMake 3.13+ with VS generator for complete support of VS versions
> # and support by AppVeyor.
> if(${CMAKE_GENERATOR} MATCHES "Visual Studio")
> -  cmake_minimum_required(VERSION 3.13 FATAL_ERROR)
> +  cmake_minimum_required(VERSION 3.12 FATAL_ERROR)
> endif()
>  list(APPEND CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake")
> Index: geos-3.8.0/src/index/chain/MonotoneChainBuilder.cpp
> --- geos-3.8.0/src/index/chain/MonotoneChainBuilder.cpp
> +++ geos-3.8.0/src/index/chain/MonotoneChainBuilder.cpp
> @@ -111,8 +111,10 @@
>          ++last;
> -        prev = curr;
> -        curr = &pts[last];
> +        if (last < npts) {
> +            prev = curr;
> +            curr = &pts[last];
> #if GEOS_DEBUG
>      std::cerr << "MonotoneChainBuilder::findChainEnd() returning" <<
> std::endl;
> *Asa Packer*  | Lead Systems Engineer
> *BioSonics, Inc.*
> 2356 W Commodore Way, Unit 110
> Seattle WA 98199-1258 USA
> *tel* 206.782.2211 |  *biosonicsinc.com* <http://www.biosonicsinc.com/>
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20191023/3b1b1fe2/attachment.html>
