[geos-devel] 3.8.0 problems building on Windows
Daniel Baston dbaston at gmail.com
Thu Oct 24 07:41:13 PDT 2019
> BTW, how do you confirm what feature set we’re using? Is there a magic
> test?
Not that I'm aware of. I said we're not using anything from > 3.8 because
that's what our CMakeLists claims, but I guess it could be wrong.
Dan
> P
> On Oct 23, 2019, at 6:13 PM, Daniel Baston <dbaston at gmail.com> wrote:
> Hello Asa,
> Thank you for the reports. I ticketed the assertion failure issue at:
> https://trac.osgeo.org/geos/ticket/1002
> I'm not sure why the CMake version check for MSVC needs to be a fatal
> error, since we're not using any features from CMake > 3.8. Does anyone
> object to changing this?
> Dan
> On Mon, Oct 21, 2019 at 3:14 PM Asa Packer <APacker at biosonicsinc.com>
> wrote:
>> Hi,
>> I just started working with version 3.8.0, trying to build it on
>> Windows.  I ran into two issues:
>>    1. Out of the box I can’t build geos 3.8.0 with a fully-updated
>>    Visual Studio 2017, because geos wants cmake 3.13 and VS2017 only has
>>    3.12.  If I change line 22 of the top-level CMakeLists.txt to require only
>>    3.12, then I can build fine in Release mode, either 32 or 64 bit, and ctest
>>    shows no failures.
>>    2. If I build in Debug mode, with either VS2017 or VS2019, I get tons
>>    of assertion failures when I do ctest.  They all come from line 115 of
>>    MonotoneChainBuilder.cpp, which on the last time through the loop causes an
>>    access of an element one past the end of a std::vector.  Even if I ignore
>>    the assertion failures, the tests show as fails because the C runtime
>>    considers these to be fatal errors.
>> Below is a patch that fixes these issues.  Are these reasonable
>> workarounds?
>> Thanks!
>> Asa
>> Index: geos-3.8.0/CMakeLists.txt
>> --- geos-3.8.0/CMakeLists.txt
>> +++ geos-3.8.0/CMakeLists.tt
>> @@ -19,7 +19,7 @@
>> # Require CMake 3.13+ with VS generator for complete support of VS
>> versions
>> # and support by AppVeyor.
>> if(${CMAKE_GENERATOR} MATCHES "Visual Studio")
>> -  cmake_minimum_required(VERSION 3.13 FATAL_ERROR)
>> +  cmake_minimum_required(VERSION 3.12 FATAL_ERROR)
>> endif()
>>  list(APPEND CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake")
>> Index: geos-3.8.0/src/index/chain/MonotoneChainBuilder.cpp
>> --- geos-3.8.0/src/index/chain/MonotoneChainBuilder.cpp
>> +++ geos-3.8.0/src/index/chain/MonotoneChainBuilder.cpp
>> @@ -111,8 +111,10 @@
>>          ++last;
>> -        prev = curr;
>> -        curr = &pts[last];
>> +        if (last < npts) {
>> +            prev = curr;
>> +            curr = &pts[last];
>> #if GEOS_DEBUG
>>      std::cerr << "MonotoneChainBuilder::findChainEnd() returning" <<
>> std::endl;
>> *Asa Packer*  | Lead Systems Engineer
>> *BioSonics, Inc.*
>> 2356 W Commodore Way, Unit 110
>> Seattle WA 98199-1258 USA
>> *tel* 206.782.2211 |  *biosonicsinc.com* <http://www.biosonicsinc.com/>
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20191024/6d7e20b7/attachment.html>
